GetScreenTabFrame
GetScreenTabFrame
GetScreenTabFrame(TabName)
When a tab containing a Screen or Frame is created on the PowerExplorer object, using the InsertScreenTab method, a Frame is created to contain that Screen, similar to what happens on an Elipse Power Viewer.
This method returns the Frame of the tab indicated by the TabName parameter, or returns a script error if this tab does not exist or it does not have a Frame, which is the case for default tabs.
This Frame is only effectively created during the first activation of a tab. Therefore, if the tab is created but never activated, this method returns a script error.
Sub CommandButton_Click()
  'Script to change the Screen of a tab of a PowerExplorer object
  Set PE = Application.GetPowerExplorer("Sub1.Breaker1")
  Set PEFrame = PE.GetScreenTabFrame("ChartTab")
  PEFrame.OpenScreen("ChartScreen2", 0)
With the Frame object, users can use some methods as if they were executed on an Elipse Power Viewer. For example, users can use the OpenScreen method to open a new Screen on the Frame, that is, on the tab. The following methods of the Frame object cannot be used because they cause a script error:
•BringToFront
•Close
•MaximizeFrame
•MinimizeFrame
•MoveFrame
•RestoreFrame
•SetForegroundWnd
•SetFrameOptions
