SelfHealingPriority |
Indicates a priority for this Load on the Self-Healing module. The default value of this property is -1 (minus one, this Load has no priority). Values greater or equal to 0 (zero) indicate Loads with a priority on the Self-Healing module. The highest priority is 0 (zero).
