MaxCharacters
MaxCharacters
Number This property establishes a limit of characters that users can type, when in edition mode, in a Text, Display, or SetPoint object. The following restrictions apply to this property:
•Configuring this property to 0 (zero) does not limit the number of characters when editing these controls, and also configures the RemainingCharacters property to 0 (zero)
•When pasting a text with more characters than the value configured in this property, that text is cut
•When changing the value of this property to a value less than the size of the text already in the control, that text is cut
•The value of this property applies to the number of characters users can type, without considering a control's format
