AreaNameOverride
AreaNameOverride
Text Determines an alternative name for the Area that contains this Alarm Source. The default value of this property is an empty String.
NOTES
•When this property is empty, the name of this Alarm Source is composed by the names of Area objects hierarchically above it.
•This property, even when filled in, does not influence Alarm Area counters hierarchically above it, which keep counting all Alarms of this Alarm Source.
•If this property is changed at run time, its new value is only effective when the next Alarm on this Alarm Source occurs.
