ID |
Unique identifier of a device in the Electrical Model. This value is usually imported from the Electrical Model, and cannot be changed at run time. When in the Electrical Model, this property is automatically assigned by the system. This is a read-only property.
NOTE |
The value of this property is a GUID String, such as "{6B29FC40-CA47-1067-B31D-00DD010662DA}". For devices that do not belong to the Electrical Model, the value of this property is "{00000000-0000-0000-0000-000000000000}". |
