ExposeToOpc |
Indicates whether an object and its respective children must be exposed to the OPC UA Server. Possible values for this property are 0 - eeUseParentConfig: Uses the configuration of this property in its parent object (default), 1 - eeExpose: Exposes this object, regardless of the configuration in its parent object, 2 - eeExposeAsReadOnly: Exposes this object only for reading, regardless of the configuration in its parent object, or 3 - eeDontExpose: Does not expose this object, regardless of the configuration in its parent object.
NOTE |
Alarm Server, Alarm Configuration, Database, Power Configuration, and Viewer objects cannot be exposed in the OPC UA Server. |
