Common Properties
Common Properties
This section contains information about the common properties of Microsoft Forms objects.
NOTE
Elipse Power uses the Himetric system to define coordinates and widths. In this system, each logical unit is the equivalent of a thousandth of a centimeter, that is, every 1,000 units correspond to one centimeter. Thus, this is the standard adopted in the description of Elipse Power properties, when applicable.
The available properties on this section are the following:
•BackColor
•ForeColor
•MouseIcon
•MousePointer
