SortOrder
SortOrder
Enum Indicates the sorting order of data based on the column indicated in the SortColumn property. Possible values for this property are 0 - SONoSort: Without sorting order (default), 1 - SOAsc: In ascending order, or 2 - SODesc: In descending order.
NOTES
•This property is only available at run time.
•Configuring this property with the value 0 (zero, SONoSort) and the SortColumn property with a value less than or equal to 0 (zero) returns the original sorting order of data from the E3Browser's Query.
