Shortcuts |
This option allows executing applications installed with Elipse Power via E3 Admin's contextual menu on Windows Notification Area. The following applications can be executed:
•Elipse Event Log Viewer
•Elipse Power Studio
•E3 Tweak
•Elipse Power Viewer
The Log Viewer
item opens Elipse Event Log Viewer, already with the file corresponding to the active Elipse Power log session. For more information about this application, please check Elipse Event Log User's Manual.
If there is a Domain already executing locally, the Elipse Power Viewer
item on this menu opens an Elipse Power Viewer to the local Domain. Otherwise, or if the SHIFT key is pressed, opens Elipse Power Viewer's initial screen, where users can select the server and other options, as described on topic Elipse Power Viewer and WebViewer - Elipse Power Viewer Execution - Via Start Menu.
