Elipse KeyPad |
Elipse KeyPad is an ActiveX control developed by Elipse Software that allows using a virtual-floating keyboard in applications developed with Elipse Power.
This control can be activated on Elipse Power Viewer by using the KeyPad group on the E3 Viewer tab of the Properties Window of the Viewer object.
Viewer's E3 Viewer tab
Available options for Elipse KeyPad on E3 Viewer tab
Option |
Description |
Show when a SetPoint gets focus |
This options always shows Elipse KeyPad when a SetPoint object receives focus |
Hide when pressing ENTER |
Enables hiding Elipse KeyPad when pressing the ENTER key. This option is equivalent to control's AutoHideOnEnter property |
Hide when pressing ESC |
Enables hiding Elipse KeyPad when pressing the ESC key. This option is equivalent to control's AutoHideOnEsc property |
In scripts, a KeyPad can be opened when using Application's GetKeyPad method. The description of the properties of this object can be found on the Elipse Power Reference and Scripts Manual.
