<< Click to Display Table of Contents >> PowerEngine and Electrical Studies |
•Implemented support for tap in Three-Winding Transformers only for models in EDB format.
•Created a representation of a tap in Three-Winding Transformers.
•Created two new input Discrete Measurements, *Bypass and *Isolation, for Topological Processor, Power Flow, Self-Healing, Load Shedding, and State Estimator modules.
•Allowed the External Reader module to provide values of *Bypass e *Isolation Discrete Measurements to the Power Flow module.
•The Load Shedding module now shows in the log the reason a ValidOutput property contains a False value.
•The PowerEngine2 library now supports Two-Winding Transformers inside Wind Power Plants and their Bays.
•A closed loop blocks the operation of the Self-Healing module only with the involved Feeders, not blocking all Feeders connected to the same Busbars anymore.
•Implemented an overload simulation in the Self-Healing module.
•The Analog Measurement *LoadSheddingSpinningReserve can receive a negative value, which indicates whether a generator must reserve power.
