<< Click to Display Table of Contents >> Elipse Power Data Objects |
•Created the DiscreteTypes property in the Power Configuration object to allow configuring types of Discrete Measurements by script.
•Created the AnalogTypes property in the Power Configuration object to allow configuring types of Analog Measurements by script.
•Created the CommandTypes property in the Power Configuration object to allow configuring types of Commands by script.
•Created the ProtectionTypes property in the Power Configuration object to allow configuring types of Protections by script.
•Created the VoltageColors property in the Power Configuration object to allow configuring colors for base voltages by script.
•Created the SwitchGearColors property in the Power Configuration object to allow configuring colors for Switch statuses by script.
•Implemented writing access to the properties of the object returned by Power Configuration's MeasurementColors property.
•Added the EuLow and EuHigh properties in Analog Measurements, which represent minimum and maximum values of a Measurement's engineering unit, respectively.
•Created a Design tab on the Power Configuration object, where this object appears and its child objects.
