<< Click to Display Table of Contents >> TargetResolutionY |
Defines Screen's vertical resolution for which this application is designed to, in pixels. The default value of this property is -1 (minus one), which assumes the current computer's resolution. This property cannot be changed at run time, even if Elipse Power Viewer is inactive.
