DataField
DataField
Text Configures or returns the data linked to a Group Header-type Section. This linked data can be a field on a database table provided by a Query object, a mathematical expression with Query fields or a Tag or property from Elipse Power. In this case, the current value of the variable is shown when printing. The default value of this property is an empty String.
NOTE
The server must be executing for a variable's value to be captured.
