<< Click to Display Table of Contents >> TapTerminal |
Terminal where a tap is placed on this Transformer. This is a read-only property. Possible values for this property are 0: No tap (default), 1: Terminal 1, or 2: Terminal 2. To change a tap's position, users must use this object's contextual menu. This value is usually imported from the electrical model.
