TransferenceColor
TransferenceColor
Color Indicates the current color of a Terminal based on the Feeder that is energizing it. This is a read-only property. The value of this property depends on the value of the TransferenceStatus property. If the TransferenceStatus property is equal to 0 (zero, tsNotTransferred), this color is equal to the color defined in the StrokeColor property of the Feeder that contains this Terminal. If the TransferenceStatus property is equal to 1 (one, tsTransferredToSingle), this color is equal to the color defined in the StrokeColor property of the Feeder energizing this Terminal. If the TransferenceStatus property is equal to 2 (two, tsTransferredToMultiple), this color is white (RGB(255, 255, 255)), indicating that more than one Feeder is energizing this Terminal.
