CommandAction
CommandAction
Number An integer that indicates the type of Command sent. Possible values for this property are 0 - caNone: No Command, 1 - caOperate: Operate Command, 2 - caSelect: Select Command, or 3 - caCancel: Cancel Command. This is a read-only property.
