<< Click to Display Table of Contents >> DeleteField |
Removes the Historic Field informed in the Index parameter, which can be a Historic Field's position (starting at one) or a Historic Field's Name property, if that Historic Field exists on the Fields object. Otherwise, this method returns a script error.
NOTE |
The E3TimeStamp Historic Field, created automatically by Elipse Power, cannot be removed. |
