<< Click to Display Table of Contents >> Refresh |
Refresh([Force])
This method allows forcing a redrawn of a Screen's or Splitter's content. It must be used in Elipse Power Viewer scripts with massive processing, such as loops, or in method calls demanding a long time and also demanding a visual indication for the progress of a process to users.
Due to the general redrawn being a heavy operation, default version of this method, without the Force parameter, is optimized to ignore redrawn requests from Elipse Power. This standard behavior is ideal for loop progress indications, where a lot of redrawing is performed. The Force parameter disables this optimization, ensuring that for each call to this method, a redrawn is performed. However, when using this option, this method cannot be called repeatedly, such as inside a loop, according to the next example.
Sub CommandButton1_Click()
' Draws a progress bar for an operation
While i < 31
Screen.Item("Rectangle2")_
.HorizontalPercentFill = (i / 30) * 100
Frame.Refresh True
' <-- some lengthy operation -->
Wend
