Alarm Server and Alarm Configuration
•Now users can configure the size of Alarm Fields of type Text on the database.
•Improved performance of Alarm Filters with sorting by fields enabled.
•Improved CPU usage of E3Run process in situations with many alarms.
•Added the ExcludeSuppressedOnAreaCounter and ExcludeSuppressedOnCounters properties to Alarm Sources and to the Alarm Server, respectively. These properties allow suppressed alarms to be excluded from alarm counters.
•Added the SuppressedAlarmsConfigured property to Alarm Sources. This property indicates that the source or sub-condition is configured to allow shelving alarms.
