Elipse Power
Elipse Power
•Fixed an empty error message about executing Commands when there are errors in the definition or syntax of Command scripts. This bug occurred since v4.8.149.
•Fixed the notification of changes in the Power Configuration object when inserting a Command using the Add option on the Commands. This bug occurred since v3.5.81.
