OPC UA Driver and OPC UA Client
•Fixed the behavior of historical OPC UA queries with less than 200 records, called from within Reports. This bug occurred since v4.5.176.
•Disabled the option to select a server on an OPC UA Driver's View. This bug occurred since v4.8.92.
•Fixed the way pending historical queries are finished when a connection with an OPC UA server fails. This bug occurred since v4.5.176.
•Now the OPC UA Client reconnects when there is an invalid session error. This bug occurred since v4.5.176.
•Fixed the categorization of the Bit00 property of OPC and OPC UA Tags on the Properties List. This bug occurred since v4.6.99.
•Fixed the handling of Node IDs of type GUID in OPC UA Client. This bug occurred since v4.5.166.
