Find and Replace
Find and Replace
•Implemented a feature of finding and replacing in User Events. This bug occurred since v1.19.124.
•Changed the option to replace only on the selected results. This bug occurred since v2.0.88.
•The find and replace tool now shows the name of the property and not a column's index, which was wrong, for the properties of a Storage Field. This bug occurred since v3.1.11.
•Fixed a problem when replacing values in Link fields. This bug occurred since v3.5.127.
•Fixed an error in which the Replace All option was not working correctly with objects in the same hierarchical level. This bug occurred since v3.1.1.
•The Match case option is correctly respected when performing a replacement in a String. This bug occurred since v3.5.130.
•The Result column on the results window of finding and replacing now must update correctly according to the executed operation. This bug occurred since v2.0.88.
•A Formula View now updates correctly when performing a replacement, and users can now find and replace in the Type and Restriction fields of Formulas. This bug occurred since v2.0.88.
•Script tabs are now updated correctly when performing replacements in Picks or in scripts. This bug occurred since v2.0.52.
•Only an Alarm Server now returns results for searches for names of User Fields of Alarm Servers. This bug occurred since v4.5.108.
•Now users cannot perform a replacement in names of objects that cannot be renamed. This bug occurred since v4.7.6.
•Now users can select correctly results of searches in Filters and Connections of E3Alarm and Alarm Filter objects.
•The selection of search results in User Fields now works correctly. This bug occurred since v4.5.167.
