Elipse Power Data Objects
•Created the Comment property in Substation, Feeder, Transmission Line, and Wind Power Plant objects. This property is synced from the model in EDB format.
•Created the TransferenceStatus and TransferenceColor properties in the Terminal object, to indicate the transference status of Feeders.
•Created the SourceType property in Discrete and Analog Measurement Sources, which indicates the type of Measurement Source.
