PowerEngine and Electrical Studies
•Created Measurements to inform the expected number of upstream and downstream devices after a maneuver of the Self-Healing module.
•Standardized the descriptions of Measurement Types of Load Shedding and Self-Healing Electrical Studies.
•Implemented new Measurements that allow signaling all downstream devices of a certain device.
•Implemented a Simulation (diagnose) tool on the Self-Healing module.
•Improved the performance of the Self-Healing module, reducing the necessary time to wait for an operator to act if the module did not find a solution.
•The State Estimator module now accepts voltage Measurements in Branches as input.
•The State Estimator module now accepts three-phase power Measurements as input.
•Now users can prevent the operation of the Self-Healing module if the timestamp of the trigger is too different from computer's current time.
•Added persistence of values of *SelfHealingDevicesDownstream and *SelfHealingDevicesUpstream Measurements to the events database of the Self-Healing module.
•Added support for load priority in the Self-Healing module.
•The Self-Healing module now handles Reclosers in Switch mode as inactive protection elements, not using them to isolate failed blocks in a restoration trigger.
