Undo Command
Undo Command
•Fixed the update of the Properties List for several common properties of native Screen objects, when Undo or Redo operations are executed. This bug occurred since v1.0.0.
•Fixed the Undo option for the Effect3D, Effect3D_X, Effect3D_Y, Effect3D_ColorBase, and Effect3D_ColorTop properties of Screen objects. This bug occurred since v1.0.15.
