Elipse Power
Elipse Power
•Now the Electrical Modeler is pre-created in background when the Power.e3 module is loaded in Elipse Power Studio to decrease the time the Power Configuration editor takes to load on the first time.
•Changed the default value of the Value property of Operator measurement sources to 0 (zero).
•Changed the default background color for all containers, from RGB(180, 180, 180) to RGB(90, 90, 90).
•Created the Failure semantics in the *ProtectionMode-type of the discrete measurement.
•Implemented the compilation of scripts in Power Configuration of command definitions.
•In Elipse Power Studio, the Commands and Discretes tabs of Power Configuration object now allow resizing the list of types, increasing the area to edit the type definition itself.
•In Elipse Power Studio, the list of script compilation messages was moved to a separate window, Script Compilation.
•Implemented in substations the conversion from Branch to Jumper and vice versa. Conversion from Branch to Jumper is allowed only if there are Branches (and their respective displays) selected. Conversion from Jumper to Branch is allowed only if there is Jumpers selected.
•Added alignment tools in PowerCAD.
•The Electrical Modeler toolbar was divided into four toolbars: General, Alignment and Grid, Elements, and Bays and Transmission Lines.
•Created the BackgroundImage property in the System, Substation, and Feeder objects of the electrical model.
•Created new methods in the PowerExplorer object to insert, remove, and manipulate tabs containing Screens: InsertScreenTab, RemoveScreenTab, and GetScreenTabFrame.
•Created a new option on Screen's contextual menu to allow importing objects from the electrical model.
•Created the CommandConfirm property in PowerExplorer, which defines whether the confirmation to send commands is requested or not.
•Created the ActiveTab property in PowerExplorer, which informs the currently active tab in PowerExplorer.
•Implemented a verification for user-created XControls when configuring the tool to import Screen objects.
•Changed two messages that warn users that the class to import Screen objects was not found.
•Implemented the GetMeasurement method also in PowerProtectionDevice objects.
•Created the BladePosition property to define the blade position in Switch and Switch Fuse objects in the PowerControls library.
•Implemented Undo and Redo options in the electrical modeler.
•Now it is possible to resize object and Screen areas on the Screen Object Importer.
•Changed the Screen Object Importer window to display Substations and Feeders in a tree, sorted by name.
•Created the OnCommandEx event in Power Configuration object.
•Created the *ProtectionOperateCurrent, and *ProtectionStartCurrent default analog measurements, and the *TapPositionA, *TapPositionB, and *TapPositionC default discrete measurements, as well as the *TapPositionA, *TapPositionB, and *TapPositionC discrete commands.
•Added the LinkNode object to the PowerControls library.
•Fixed the import process to use the new LinkNode object in PowerControls library.
•Added the LinkNode object on some Screens in Elipse Power's demonstration application.
•Protection measurements (PowerProtectionDevice) now can be sent to Electrical Studies (PowerEngine).
•Created the Recloser data object.
•Created the Voltage Regulator data object.
•Revised the icons of electrical elements, vertically standardizing terminals.
•Added a progress bar for the Add Standard Measurements option.
•Changed the PowerExplorer implementation to use a new data grid component.
•Created two new properties in PowerExplorer, SelectionColor and SelectionColorInactive, which configure the background color of grid cell on measurement tabs (Analogs, Discretes, and Protections) when the cell is selected or selected and inactive, respectively.
•The title of PowerExplorer window, when opened via LinkNode, now follows the same pattern of other PowerControl objects.
•Changed the Project Wizard to copy and add to the Domain the default Power libraries (PowerControls and PowerDisplay).
•Now the PowerControls and PowerDisplay libraries are also present in Libraries folder, created during the installation.
•Created the AnalogInputMode property in PowerExplorer.
•In Elipse Power Studio, at the end of the application Wizard, if created a standard application, the Electrical Modeler is opened, already with the name of the model file configured.
•Created the Voltage Regulator graphical object for use with the Voltage Regulator data object.
