Documentation
Documentation
•Updated the minimum requirements to install Elipse Power and Elipse Power Viewer in Third-Party Licenses in Elipse Power.
•Updated the Gold Independent Software Vendor logo, USA branch address, and added a link to KB in the final page of Elipse Power documentation in PDF format.
•Updated the Microsoft Partner and OPC Member logos of Elipse Power documentation in PDF format.
•Added the OPC Foundation MIT license in the license document of Elipse Power.
•Updated the table of fields of a Pen's Legend with information about the number and name of each column, in Elipse Power User's Manual, as well as in Elipse Power Reference and Scripts Manual.
•Updated the description of the DefaultValue, HelpString, and Retentive properties of an ElipseX Property object in Elipse Power Reference and Scripts Manual.
•Updated the description of the SetDisableTaskSwitching method of the FrameSet object in Elipse Power Reference and Scripts Manual.
•Updated all models to generate PDFs for A4 printing format in all documents, except the Third-Party Licenses in Elipse Power.
•Added an exercise about the PowerChartFilter object in the Query chapter of Elipse Power Tutorial. Excluded the exercise about the PenGroup object, in this chapter.
•Added a chapter about Protections in Elipse Power Tutorial.
•Added a topic about Discrete Alarms in Elipse E3 Tutorial Developer and in Elipse Power Tutorial.
•The exercise in the Hot-Standby - Configuring Hot-Standby chapter of Elipse Power User's Manual was changed to remove the explanation about every configuration option and replace them by links to specific topics in the chapter about Domains.
•Removed the topic List of Events, of Drivers chapter of Elipse Power User's Manual, which was replaced by the topic Tags Reported by Events.
•Added a note in Elipse Power User's Manual explaining the functionality of the Disable permissions check on Elipse Power Studio's Permissions tab.
•Added a description of Power Configuration object’s OnCommandEx event to Elipse Power Reference and Scripts Manual, as well as the descriptions of PowerCommandInfo’s properties used in this event.
•Added information on Voltage Regulator object in Elipse Power User's Manual and Elipse Power Reference and Scripts Manual.
•Added EQATEC Analytics license to Third-Party Licenses in Elipse Power.
