Viewer
Viewer
•Fixed a problem that prevented Read-Only Elipse Power Viewers from accessing via script properties and methods of Domain objects. NOTE: It also requires an update on the remote server if the Remote Domain channel is not read-only. This bug occurred since v3.0.201.
•Fixed a retry in the REC connection when resolving the server's name fails. This bug occurred since v1.21.98.
•Fixed a memory leak that occurred in Elipse Power Viewer during a Screen toggling with Elipse Power Viewer's cache disabled. This bug occurred since v4.0.128.
