Links
Links
•Corrected a problem which occurred when a row in a Multiple Link was created at run time and the Link of that row got a bad quality. This bug occurred since v3.2.85.
•Corrected a GPF which may occur during the handling of reentrant variations of Links. This bug occurred since v1.18.147.
•Improved failure logs of sending Link events from E3Run to E3 Server, as well as improved the logic of quitting in case of repetitive failures. This bug occurred since v1.18.147.
•Corrected a problem with Links using Local Aliases which were not reconnecting correctly. Now, Links which use Local Aliases and are created disconnected, behave as Links which were created connected, that is, they are created and maintained without considering the Domain as part of their path. This bug occurred since v3.1.203.
