Properties
Properties
To create a script in a Report, use the Report's Script Editor, opened by clicking Scripts Editor and to view a Report, click Generate Report. Both options are available on the toolbar of a Report.
Report scripts use some procedures, depending on the object or Section where users want to include code. For example:
Report.Sections("PageHeader").Controls("E3Chart1")._
  GridBkColor= RGB(255, 0, 255)
Where:
•PageHeader: This is the name of the Section where this object is inserted in a Report
•E3Chart1: This is the name of the object that is inside the specified Section, in this case PageHeader
•GridBkColor: This is the object's property name, in this case E3Chart1
•RGB (255, 0, 255): This is the property's parameter or action. In this case, changing chart's background color to pink
Therefore, to create a script in a Report, use the following concept:
Report.Sections("SectionName").Controls("ObjectName")._
  PropertyName = property_parameters
NOTE
The Report object encapsulates an ActiveReport (or AR) object, which is the Report itself.
The available property on this section is the following:
•Caption
