Properties
Properties
This section contains information about the properties of a Report's Layout (ActiveReport) object.
NOTE
All properties described here are part of the ActiveReport (AR) object, which is encapsulated in a Report object. These properties are only valid inside AR's scope and cannot be accessed from outside this object.
The available properties on this section are the following:
•_PageBottomMargin
•_PageLeftMargin
•_PageRightMargin
•_PageTopMargin
•AllowSplitters
•documentName
•MaxPages
•ParentReport
•PrintWidth
•RulerVisible
•ScriptDebuggerEnabled
•ScriptLanguage
•ShowParameterUI
•Status
•TOCEnabled
•TOCVisible
•ToolbarVisible
•UserData
•Version
•WaterMark
•WaterMarkAlignment
•WaterMarkPrintOnPages
•WaterMarkSizeMode
