DataSourceSize
DataSourceSize
Number Indicates the maximum size of Unit fields on the Database table. Default value of this property is 200 and its value must be positive.
NOTES
•This property's data type is a 32-bit integer, but it depends on the data type defined by the database server used (Access, SQL Server, or Oracle).
•Change this property to a value less than the previously configured may result in truncating data already stored on the Database table.
