Properties
Properties
This section contains information about the properties of an E3Alarm object.
NOTE
Elipse Power uses, when defining coordinates and widths, the Himetric system. In this system, each logical unit is equivalent to one hundredth of a centimeter, that is, every 1000 units are equivalent to one centimeter. Thus, this is the standard adopted when describing Elipse Power properties, when applicable.
The available properties on this section are the following:
•ActiveAlarms
•ActiveCritAlarms
•ActiveCritNACKAlarms
•ActiveHighAlarms
•ActiveHighNACKAlarms
•ActiveLowAlarms
•ActiveLowNACKAlarms
•ActiveMedAlarms
•ActiveMedNACKAlarms
•ActiveNACKAlarms
•AlarmCount
•AlarmServer
•AllowAckAll
•AllowAckCurrentFilter
•AllowAckSelected
•AllowColumnClick
•AllowDeleteUnboundAlarms
•AllowShelveAlarms
•AreaFilter
•BannerMode
•BorderColor
•BorderThickness
•ColorAckedAlarm
•ColorActiveAlarm
•ColorActiveEvent
•ColorNAckAlarm
•ColumnHeader
•Connections
•ConnectionStatusBarColor
•CustomFilter
•Domain
•EnableSortMarker
•Events
•Fields
•Filters
•FilterType
•Font
•FourthSortAscending
•FourthSortField
•GridBkColor
•InactiveCritNACKAlarms
•InactiveHighNACKAlarms
•InactiveLowNACKAlarms
•InactiveMedNACKAlarms
•InactiveNACKAlarms
•PictureConnected
•PictureNotConnected
•PictureUnknown
•PopupMenu
•PrimarySortAscending
•PrimarySortField
•SecondarySortAscending
•SecondarySortField
•ShowConnectionStatusBar
•ShowCriticalPriority
•ShowHighPriority
•ShowIcon
•ShowLowPriority
•ShowMediumPriority
•SimpleAreaFilter
•ThirdSortAscending
•ThirdSortField
