Common Properties
Common Properties
This section contains information about the common properties of E2Control objects. The available properties on this section are the following:
•Frame_BorderColor
•Frame_BorderEnabled
•Frame_BorderThickness
•Frame_Color
•Frame_Enable
•Frame_Enable3D
•Frame_Separator
•Frame_Set3DInset
•Frame_Thickness3D
•Frame_Title
•Frame_TitleColor
•Frame_TitleEnabled
•Frame_TitleFont
