Documentation |
•Added a note in the GradientStyle property, common to Screen objects, indicating that this property is not available for the Picture, Dynamic Move, and Dynamic Rotate objects on Elipse Power Reference and Scripts Manual. This bug occurred since v3.5.187.
•Fixed the description of the fmTextAlignCenter option of the TextAlign property of MS Forms objects Checkbox, Text, and Option Button on Elipse Power Reference and Scripts Manual. This bug occurred since v1.20.449.
•Fixed the name of the Error event, common to MS Forms Screen objects on Elipse Power Reference and Scripts Manual, which was incorrectly identified as OnError. This bug occurred since v3.2.118.
•Fixed the description of Viewer's LoadFormulaDlg method to contain more precise information about its parameters and return value on Elipse Power Reference and Scripts Manual.
•Updated the description of columns MinRecTime, MaxRecTime, Dead Band, and Unit on topic Storage - Settings of Elipse Power User's Manual. This bug occurred since v1.21.1.
•Updated the picture of AppBrowser on Elipse Power User's Manual and on Elipse Power HMI Tutorial where it displays the Tasks node, and also updated the descriptive text on Elipse Power User's Manual. This bug occurred since v4.5.252.
•Updated the description of several properties on Elipse Power Reference and Scripts Manual to add information that these are read-only properties.
•Removed examples referring to several properties of Screen object Dynamic Move on Elipse Power Reference and Scripts Manual. This bug occurred since v1.20.1.
•Fixed the formatting of several styles on Elipse Power documentation to avoid orphan lines in PDF format. This bug occurred since v4.8.24.
