Domain Library Files Information |
The Domain Library Files Information (LibFilesNode) object does not contain events, methods, or properties associated to it, only the general properties Count, Name, and Parent, in addition to the general method Item. Users can also use the For Each statement to enumerate this collection's child objects.
NOTE |
Using brackets when referencing this object in scripts, such as "[?Server].Domain.Files.Lib", is mandatory. |
