Application Folder |
The Application Folder (RuntimeFolder) object is similar to a Data Folder object from a Data Server, allowing to group Server objects inside folders. However, there are important differences:
•An Application Folder object is only available at run time
•An Application Folder object contains the general properties Application, Count, Name, Parent, and PathName, and also the general methods Item and Save
•An Application Folder object allows using the For Each statement to enumerate its child objects, but that kind of access only takes into account Server objects, not listing, for example, Screens and Resources inside Folders
•The root folder from where users can enumerate objects is always the Server object
