<< Click to Display Table of Contents >> Properties |
This section contains information about the properties of a Report's Layout (ActiveReport) object.
NOTE |
All properties described here are part of the ActiveReport (AR) object, which is encapsulated in a Report object. These properties are only valid inside AR's scope and cannot be accessed from outside this object. |
The available properties on this section are the following:
