Bay |
A Bay (PowerBay) object does not contain events, methods, or properties associated to it, only general ones. These ones can be viewed on sections Common Methods and Common Properties.
NOTE |
The class of a Bay object, regarding scripts, is different on the following objects: •On a Wind Power Plant, the class of a Bay object is WindBay. •On a Photovoltaic Power Plant, the class of a Bay object is PhotovoltaicBay. •On a Feeder, the class of a Bay object is PowerFeederBay. |
