SetValue |
SetValue(TagName, NewVal)
This method sets the value of an object inside a server. This method searches for an object or property executed on a server and sets the value specified in the TagName parameter. The type and value of the NewVal parameter must be supported by the object specified in TagName. The next code contains a usage example of this method.
Sub Button1_Click()
' When clicking Button1 sets value 20
' to Value property of the tag
Application.SetValue "DataServer1.InternalTag1", 20
