Logout |
Logout([Mode])
Executes a logout, when the current user quits an application, from Elipse Power Viewer. In case there is no logged-in user, this method has no effect. From this moment on, it is considered that an "Anonymous" user is using that application. Users can use the OnLogout event to perform a script to go to its initial Screen or end that application. This method contains an optional Mode parameter, which is a Boolean determining whether a confirmation or failure message must be displayed. If this parameter is omitted, the confirmation or failure message is not displayed.
