IsAppRunning |
IsAppRunning(ProcessId)
Indicates if an application started by the ExecuteExternalApp method is currently executing. Returns True if an application identified on the operating system by ProcessId is executing. Otherwise returns False. The next code contains a usage example of this method.
Sub CommandButton1_Click()
Application.ExecuteExternalApp _
"www.elipse.com.br", "", "", 1, processID
While Application.IsAppRunning(processID)
' Waits for this application to end
Wend
MsgBox "This application ended!"
NOTE |
The ProcessId parameter is the same value appearing on Windows Task Manager, on PID column. |
