GetMouseX |
GetMouseX()
Returns mouse pointer's X coordinate, in pixels, relative to the entire area of computer's screen.
NOTE |
This method fails in a script if the current mouse pointer position cannot be retrieved. One of the situations where this failure can be verified is when Windows Logon window opens, that is, when pressing the shortcut key CTRL + ALT + DEL. This behavior of preventing access to the current mouse pointer position is default on Windows in some situations and cannot be overridden. As a suggestion, use the On Error Resume Next statement before using this method to prevent script errors. |
