EUHigh |
Defines the maximum value to set to the Value property, adjusting the scale to the value on a device before this attribution. Likewise, at the moment of the writing the inverse operation is executed before sending a value to the Driver. This conversion only occurs when the EnableScaling property is set to True. Default value of this property is 1,000.
