LineStyle |
Determines a style for Ellipse, Rectangle, and Rounded Rectangle objects' line. The available options for this property are described on the next table.
Available options for the LineStyle property
Option |
Description |
0 - ddLSTransparent |
Line remains transparent |
1 - ddLSSolid |
Line appears solid (default) |
2 - ddLSDash |
Line appears dashed |
3 - ddLSDot |
Line appears dotted |
4 - ddLSDashDot |
Line appears with a dash-dot pattern |
5 - ddLSDashDotDot |
Line appears with a dash-dot-dot pattern |
