Alignment |
Determines the text alignment on a Text. Possible values for this property are 0 - rv2Left: Text aligned to the left (default), 1 - rv2Center: Text aligned to center, 2 - rv2Right: Text aligned to the right, or 3 - rv2Justify: Justified alignment.
