LineWeight |
Specifies the line width of a Line object. Configuring the width to 1 (one), the object's line expands up to 15 points. Configuring the width to 2 (two), line is expanded up to 30 points, and so on. The greater the number configured in this property, the greater the object's width. Default value of this property is 1 (one).
