DataField |
Configures or returns the data linked to a Field object. This linked data can be a field on a database table provided by a Query object, a mathematical expression with Query fields or a Tag or property from Elipse Power. In this case, the current value of the variable is shown when printing. The default value of this property is empty.
NOTE |
The server must be executing for a variable's value to be captured. |
