CaptionPosition |
Specifies the position of the text indicated in the Text property. The available options for this property are 0 - rv2NoCaption: Text appears on the Bar Code (default), 1 - rv2Above: Text appears above the Bar Code, or 2 - rv2Below: Text appears below the Bar Code.
